Yes - and how much foam are we talking about? Take a look in the oil tank on a Harley after it's been running any length of time and you will always see some amount of bubbles. These are dry sump engines - an oil (pressure) and a scavenge pump.
Interesting that the MoCo would replace three engines without screaming foul - e.g. trying to void your warranty because you didn't use the recommended Harley oil. If they could prove that it was oil-related then I'm sure that they would........
There's more here than meets the eye.
