mva
Thread starter
Lots of different opinions here. Obviously, every vehicle/tire/driver combination will produce different subjective and objective results.
I increased the tire pressure on my Honda Accord from 32 up to 44 psi all around. There is a bit more road noise, the ride is slightly rougher but still fine for me. The handling seems a bit crisper. I am curious if I will be able to detect a change in mpg. It's not that I can't afford the gas - I find it fun to experiment in improving mpg.
I will admit that Honda's recommended tire pressure probably provides the best compromise between ride, handling and fuel economy. But contrary to other opinions posted here, I don't expect any significant problems with traction, tire wear, suspension wear or hydroplaning.
1 mpg or even 0.5 mpg may seem minor but it is pretty significant if spread over a large number of vehicles. Gas here in Canada currently costs 1.25 $/litre (4.80 US$/US gallon). If a set of tires lasts 50,000 miles, going from 31 to 32 mpg will save 50 gallons of gas or $240 over the life of the tires. This is 3% improvement in mpg on a light weight econo car; the savings should be proportionally greater on a larger heavier vehicle.
1% fuel savings on all US vehicles would save up to 1,400,000,000 gallons of gas per year.
Yes, the US population burns 140 billion gallons of gasoline per year.
The point of my original post is that higher pressure combined with low rolling resistance tires can significantly improve mpg on any vehicle. And that low pressure (less than 35 psi in Tirerack's example) can significantly increase hydroplaning.
There is limited data on low rolling resistance tires but Michelin Energy series and Goodyear Viva 2's are both advertized as low rolling resistance. I havn't tried either but will certainly consider them next time I buy tires.
California is currently pressing tire manufacturers to include ratings for rolling resistance on all tires. They are trying to implement an efficiency rating system without compromising tire wear or safety. Here is an extensive report on this topic from California's fuel efficient tire program:
http://onlinepubs.trb.org/onlinepubs/sr/sr286.pdf
