- Joined
- Sep 28, 2002
- Messages
- 39,799
My wife's jeep has been plagued with fuel issues. It always responded well to stuff like Gumout Regane and Amsoil PI way too often. All the UOA's showed fuel ..not gross amounts, but enough to upset and confound my 0w-10/20LITE experiments.
Anyway, I picked up a set of 3.7 mopar injectors out of a 2005 Liberty. They were used but appeared brand new. The installation was a snap and no snags. Now I did have to unplug a few sensors off of the throttle body to manage the fuel rail ..but nothing got stretched and everything is back in place. The thing runs perfectly. One interesting note. The OEM Jeep injectors are a single nozzle deal, while the Liberty is a 4 nozzle deal. They're both (allegedly) rated @ 24# ..which I thought was high.
A day later, and I get a P0138 code which is the 02 sensor reading abnormally high. I had also changed out the catalytic converter on the same day and was afraid that I had bought some defective reject that a liquidator had got their hands on. If I had seen a "cat efficiency" code I would have been fit to be tied.
I'll recheck the connections ..but I'm hoping that this is some transitional thing with the PCM factoring the newer injector flow in its short term calculations.
Anyone else have this happen?
btw- for 140k ..the OEM cat only had about a dozen visible "squares" that were blocked. The vast majority of the visible mesh/honeycomb was open.
