Hey everyone this is my first attempt at posting a UOA so sorry if it doesn't come out quite right. If anyone knows how to post a PDF please let me know. I have three other reports but I'm crunched for time and can't post those yet, but here are the results of the most recent. Comments concerns, are very welcome. Thanks in advance. Oh yeah I used an Amsoil EAO88 Oil filter and this was done by Blackstone thanks again
Make/ Model: 6.0 Powerstroke/Diesel
Oil Type & Grade: Amsoil 15w40
Oil Use Interval: 9497 Miles
ERIC: You certainly got the most out of this fill of 15W/40 by going nearly 10,000 miles on it. Your engine didn't mind and for an oil run this long, wear looks great! Only a slightly low viscosity kept this from being a perfect report. It was just slightly low and isn't a problem. No fuel, coolant, or moisture was found and your air and oil filters are working well, too. The TBN read 6.2 so you had plenty of active additive remaining. 1.0 is low. Had you wanted to run this oil longer we think you easily could have done so. Try 11,000 miles on the next fill. Nice wearing engine.
Miles on Oil: 9497
Miles on Unit: 35714
Sample date: 3/8/08
Make up Oil: 0
Aluminum 3
Chromium 1
Iron 22
Copper 6
Lead 6
Tin 0
Moly 3
Nickel 1
Manganese 0
Silver 0
Titanium 0
Potassium 4
Boron 2
Silicon 11
Sodium 4
Calcium 3943
Magnesium 11
Phosphorus 1278
Zinc 1383
Barium 0
Sus Vis @210 C 67.1
CST Vis @100 C 12.17
Flashpoint in F 420
Fuel % Antifreeze % 0
Water % 0
Insolubles % .4
TBN 6.2
Miles on Oil: 9497
Sample date: 3/8/08
Make up Oil: 0
Aluminum 3
Chromium 1
Iron 22
Copper 6
Lead 6
Tin 0
Moly 3
Nickel 1
Manganese 0
Silver 0
Titanium 0
Potassium 4
Boron 2
Silicon 11
Sodium 4
Calcium 3943
Magnesium 11
Phosphorus 1278
Zinc 1383
Barium 0
Sus Vis @210 C 67.1
Flashpoint in F 420
Water % 0
Insolubles % .4
TBN 6.2
