Hi there,
I'm projecting to remote mount my oil filters.
My truck is a K1500 Chevy truck , year 1996, with the 6.5 turbo diesel engine.
Usually, I use the PH5 FRAM oil filter (13/16"-16 threads and 3/4" O-ring, no By-pass valve), but the oil filter adapter I have bought only accepts oil filters such as the PH8A (3/4"-16 threads and 2 5/8" O-ring, By-pass valve 8-11PSI)
Are the PH5 and the PH8A interchangeables in usage?
The 6.5 Chevy has a By pass valve built in block (17-19 PSI), so, is it possible to use the PH8A (or cross reference) on such an engine or is it not recommended?.
If not, wich one have following specs (WIX, AMSOIL, BALDWIN or equivalent):
Style: Spin-On Lube Filter
Type: Full Flow
Media: Paper or synthetic
Thread Size: 3/4-16
By-Pass Valve: None
Anti-Drain Back Valve Yes
Burst Pressure-PSI 270
Maximum Flow Rate 9-11 GPM
Nominal Micron Rating 19
Gasket Diameters : 2 5/8"
Thank you for your help.
Type: Full Flow
Thread Size: 3/4-16
By-Pass Valve: None
