What do you guys think of this?
Shouldn't the filter be under pressure? And that would make it explode, not implode?
http://www.ls2gto.com/forums/showthread.php?t=230377
Quote:
The last time i ran at the track i noticed at the end of my run(at the top of 4th) my check oil warning came on. i pulled over and checked the oil, it was full. at that time i assumed that the "check oil" warning meant that level was low (not low pressure). i figured the the oil had just not had time to drain back to the pan to the level of the "LOW OIL LEVEL SENSOR".
Yesterday i was taking my car from where i work, to the shop directly next door to have tires put on it. on my way i proceeded to do a burnout, and around 4500rpm the warning came on. I pushed the clutch in, came to a stop, and the motor went BANG. it is locked up tight.
I could not figure out what could have happend. pulled the fram filter down, and it was imploded. then i realised that i changed the oil the day before i last went to the track and put a fram on for the firs time.
