Originally Posted By: mjo
Originally Posted By: 96 Cherokee
If I could figure out a way to mount one on my Grand Caravan, I would buy another one.
There's an easy solution for this. You can make a gravity-feed system with a pot, couple of hose barbs, some hose, and a BP filter. It's best if you set it up in your garage and put the reservoir strapped to a shelf - but it's also portable. I have one in my trunk that I put on the roof of my car when filtering stuff.
They're good for the environment and convenient. Instead of disposing of 2-3 gallons of antifreeze just filter it a few times and dispose of the TP roll.
mjo
I have actually thought about this, but it would be a lot of work.
What Ralph is talking about is, apparently, the Water Wetter in my coolant destroyed the epoxy coating on the inside of the TP filter housing. I had to change the water pump in my Jeep shortly after that incident and after removing the old pump, it appeared that there was no coolant coming out of the weep hole, it was leaking through the gasket. My best guess is the Water Wetter also ate through the gasket. Well of course I flushed out the engine very thoroughly and there will be no more Water Wetter in my engine. Lesson learned. The Ralph Wood TP filters I am using on my motor oil and transmission fluid on the same vehicle show no problems with the coating. I just wish I had learned about the TP filter many years ago. Could have saved myself thousands of dollars, literally.
