[Can we see the solid reference where RLI is used in NASCAR?]
Well excuse meeee.
My mistake ASA not NASCAR but the motors are close if not the same 8,500rpm red at 9,000 same type of motor in those days and a 358ci chevy at that!
I'll give my fingerprints too!
Renewable Lubricants Inc. March 1, 2004
Mr. William W. Garmier, Vice President
476 Griggy Rd, N.E.
Hartville, Ohio 44632-0474
Dear Bill:
Thanks for the interest in Volunteer Performance racing team, since 1999 our racing program has done
nothing but move forward in performance and reliability.
In November 1998 when we were first introduced, I will admit that a vegetable oil based product seemed
impossible. Then we tested the biobased lubricants in the shop, then on the track and with your willingness
to follow my leads and suggestions the tests were a complete success. I felt totally confident with you and
your products. Some of the tests included a Superflow Dyno 3 day engine session on a 358 Cubic Inch, 18
Degree, and 9.1 CR testing at RPMs of 5000 to 8500. Once we arrived at the track we installed the vegetable
based oil and proceeded to run the next series of testing, 25-50-125 laps ranging from 5000 to 8500 RPMs.
During the first 25 lap session, driver Gary Helton noticed by closely monitoring the oil pressure and
temperature gauges the significant raise in oil pressure (15 PSI) and decrease in oil temperature (30 Degrees).
This pressure and temperature held true through the remainder of the laps at 411 Motor Speedway. With this
many laps on the engine I traveled back to the shop, disassembled the engine an inspected all bearings, valve
train components and cam roller lifters (which I have found in the past take most of the wear and tear and
have seen trouble when using synthetic oils). Problems were eliminated with RLI Super High Performance
Racing Lubricants.
At the end of my evaluation, I found no scuffing or gaulding of any kind and was completely satisfied and
ready to take on the 1999 racing season with your products.
The Volunteer Performance/Volunteer Chevrolet #44, along with Gary Helton behind the wheel, set a new
track record at our first Southern All Star race and claimed the pole position in the Early Bird 100 held in
Birmingham, Alabama. From that point on the season and race car were flawless. As I performed routine
maintenance (valve springs, valve guides, roller lifters and engine bearings) on the engine, I discovered less
wear and fatigue. For example, the engine bearings that I currently use are a Teflon coated type bearing (rod,
main and cam bearings), normally the Teflon is either worn off or at least 75% of the coating still remained.
In addition, the roller lifters that normally show scoring by 400-600 laps, again by using your products, at the
end of 800 laps there were still no signs of scoring. As the season progressed the Volunteer
Performance/Volunteer Chevrolet #44 claimed 3 other pole positions, several top 5 positions and 2 event
wins. When it was all said and done #44 completed over 3000 laps and secured the 1999 Southern All Star
Super Late Model championship.
I have found that your Biobased Engine oil is the best lubricant thus far. We are now using RLI Biobased
Lubricants in the engine, transmission, and differential with great success. I am excited and feel fortunate to
be pioneering light weight Biobased lubricants for the racing year industry with you and your company.
Sincerely,
Robbie White
Volunteer Performance Racing Engines
[Who cares who sponsors what product? It's nothing but marketing. You don't believe the PGA golfers really eat Nature Valley granola bars (their sponsor) for better performance?]
I was curious!
