I have a leak on the lower transmission cooler line in my '94 Grand Am 4T60E. What is the best way to do an in-place fix? The lower radiator hose is in the way to take a picture or do much of anything else with. The picture is, of course, of the upper connection. It is identical to the lower connection sans leak. I don't want to have to drain the radiator again to remove the lower hose. I can't tighten anymore with the crowfoot wrench.
