Originally Posted By: Shannow
Yes it is.
set fire to a jar of regular, and a jar of premium. The premium won't leave a half jar of deposits due to an "incomplete burn".
If the engine can't adjust to the better fuel, it will simply not obtain any advantage by using it. It will NOT end up "resulting in dirty deposits, dirty oil"...that's the myth (along with increased chamber deposits)
My speculation for the continuation of the myth is from the heavily leaded fuel days. Those who played with AV fuels and whatnot would get very heavy deposits on valves and whatnot that turned into "burnt valves" in a misnomer of their condition. They would have tons more in deposits ..which would, in turn, cause more detonation due to either higher compression ..or heat retention (glowing deposits). This would lead to a few blowing holes in pistons ..hence, "It melted my engine".
This has nothing to do with the resistance to (unintended) ignition or the resistance of flame front fragmentation in flame front propagation.
