Amsoil and light weight oil
by Bullwinkle007
02/22/18 08:38 AM
What type of Dog Breeds do you own?
by pengem
02/22/18 08:30 AM
Calling AR guys - AR 10 Rear Sight options
by stockrex
02/22/18 08:00 AM
Alexa for seniors
by callbay
02/22/18 07:05 AM
229.51
by RogerBacon
02/22/18 06:25 AM
One way to get the rust off under your vehicle...
by rollinpete
02/22/18 04:04 AM
Loud hum noise from front brakes
by Jimmy9190
02/21/18 10:47 PM
Rat: Trap or Poison
by WhyMe
02/21/18 10:27 PM
STIHL Hp ultra fail??? Or my fault???
by Matt2stroke
02/21/18 09:42 PM
Wrestling pretzel hold. Ouch!
by callbay
02/21/18 09:41 PM
Serpentine Belt noise
by Tdbo
02/21/18 09:31 PM
Coolant Leak
by Ducked
02/21/18 09:13 PM
Does lots of starts let gas get in oil?
by tc1446
02/21/18 08:44 PM
Avalanche front and rear diff change.
by spasm3
02/21/18 08:40 PM
Abuse proof rental home flooring
by Oldtom
02/21/18 08:17 PM
Low Noise Oil
by Ducked
02/21/18 07:55 PM
2017 Dodge charger review
by gabriel9766
02/21/18 07:51 PM
Dry reusable air filters?
by WillB
02/21/18 07:42 PM
Batteries @ Menards
by Tdbo
02/21/18 07:29 PM
Blotter Spot Test
by Emanuel
02/21/18 07:22 PM
WiseOne, ryan6548, pjmbull, 92zx, Ara
64253 Registered Users
79 registered (4WD, BAJA_05, A_Harman, 2004tdigls, 2015_PSD, Andrei, 6 invisible), 1452 Guests and 101 Spiders online.
64253 Members
65 Forums
278525 Topics
Page 1 of 3 1 2 3 >
#1066770 - 01/17/08 01:50 PM Converting Used Motor Oil to Diesel
Mobile_Oilguy Offline
Loc: Texas
Yeah... Really...
I've been working on a processor for a few years now and it is real... You can heat used motor oil until it vaporizes and then condense it into diesel (among other things)
I am working on a plant with a foot print of about 5'x 8'x 8'tall and I should have it running very soon.
Think about this...
How much used oil is generated every day?
How much do you have to pay for it?
#1067001 - 01/17/08 08:06 PM Re: Converting Used Motor Oil to Diesel [Re: Mobile_Oilguy]
Max_Wander Offline
Loc: orwellian sheep land?
home made refinery!
#1067012 - 01/17/08 08:29 PM Re: Converting Used Motor Oil to Diesel [Re: Max_Wander]
Loc: Texas
 Originally Posted By: Max_Wander
home made refinery!
Yeah... I built a batch machine and it worked really well but I wanted a continuous production machine that will pump out 6-12GPH without having to babysit it... I am on version 3.0 and I have high hopes for this one... should be test firing in about a week... maybe 2 depending on weather.
#1067125 - 01/17/08 11:19 PM Re: Converting Used Motor Oil to Diesel [Re: Mobile_Oilguy]
Steve S Offline
Loc: East of IGO
Interesting keep us informed.
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#1067820 - 01/19/08 12:26 AM Re: Converting Used Motor Oil to Diesel [Re: Steve S]
Shannow Offline
Loc: 'Stralia
Mobile_Oilguy,
can you give us some more details on how you do it ?
What sort of equipment, how much heat input, how is it heated ?
Where'd you come up with the idea ?
What sort of viscosity are you getting ?
Don't waste your time looking back.
We aren't going that way
#1067965 - 01/19/08 09:35 AM Re: Converting Used Motor Oil to Diesel [Re: Shannow]
Loc: Texas
There is a group of people around the world that are trying different designs... We have a forum dedicated to it at http://www.oiltodiesel.com
The process is actually very simple... You heat waste motor oil to about 750-1000*F and then condense the vapors at between 300-700*F and you have diesel...
As far as equipment >> We all have different ideas as to what to use but it all achieves the same result.. Our goal is to make the process and the processor simple enough and cheap enough for the average handyman to build and use.
Viscosity and color is the same as diesel/kerosene.
Most all of the oils lighter than diesel have already been extracted>> the primary objective of the oil companies is to produce gasoline and the "Motor Oil" is one of the byproducts. So if you think about it >> What you have left is Kerosene, Diesel, Lubricating oil, & Fuel oil in th motor oil you buy....Along with all the particulates that it picks up in your motor... We are just distilling out the lighter oils and leaving the heavy oils and the trash there... I have a lube business and the recyclers that picks up my oil now pays $.70 a gallon so I will even get payed for the left overs when I am done...
Another interesting thing to think about is that >> say I have to babysit my machine and it produces 10GPH (which is about what I got out of my last batch type machine) that is equivalent to making $30 per hour with todays fuel prices >> Or I could pay a guy $10 to sit there and still make or save $20 an hour >> I currently spend about $1000 a month on fuel so this would be a huge savings.
#1068068 - 01/19/08 01:12 PM Re: Converting Used Motor Oil to Diesel [Re: Mobile_Oilguy]
Max_Wander Offline
yes yes, the oil industry's best and longest withheld truth!
#1068069 - 01/19/08 01:13 PM Re: Converting Used Motor Oil to Diesel [Re: Max_Wander]
Max_Wander Offline
Thats very nice though, you darn near energy independant now
#1068150 - 01/19/08 04:39 PM Re: Converting Used Motor Oil to Diesel [Re: Mobile_Oilguy]
Shannow Offline
Loc: 'Stralia
Thanks for the info.
#1068304 - 01/19/08 08:36 PM Re: Converting Used Motor Oil to Diesel [Re: Shannow]
LargeCarManX2 Offline
Loc: Up here in the NorthWest
What type of fuel or power are you using to heat the temp of the oil burner? And, have you figured the cost of the heating/burner costs into your formula of the finished product? Interesting stuff.
"Success is the ability to go from one failure to another with no loss of enthusiasm."
Sir Winston Churchill
#1068318 - 01/19/08 08:50 PM Re: Converting Used Motor Oil to Diesel [Re: LargeCarManX2]
XS650 Offline
Loc: Northern CA
He said he's swimming in used oil, an excellent heating fuel.
With some ingenuity he might be able to use the leftover petro product that doesn't turn into diesel.
Whenever you find yourself on the side of the majority, it is time to pause and reflect.
--Mark Twain
#1068420 - 01/19/08 11:30 PM Re: Converting Used Motor Oil to Diesel [Re: LargeCarManX2]
Loc: Texas
Right now I am using a Beckett Burner like what you would find in a regular boiler or furnace and I am running it on diesel... I am going to modify it later to run on oil>>> but I want the machine running before I play around with that part... I know when I start running oil it is going to run hotter which will help production.
And No.. I haven't figured it into final product cost yet.
That is my goal >> to use a portion of the left over heavy oil to run the burner in the furnace... Shouldn't be too difficult. I will sell the rest of the left overs to my recycler which will lower the final product cost.
I am hoping that my cost will just be the electrical cost for running the burner which will be $.05 - $.25 a gallon!
#1081715 - 02/08/08 08:15 AM Re: Converting Used Motor Oil to Diesel [Re: Mobile_Oilguy]
oilyriser Offline
Loc: Ontario, Canada
There's a Wal Mart in the US with a pilot project where they're saving up the oil from their lube service, and using it to heat the place in winter.
There might be varnish buildup in your fuel system when running this stuff, since it's been exposed to very high temperatures, and might have some chemical loose ends on the molecules. Perhaps adding 5% biodiesel would keep that in solution.
If you can build a pressure vessel that can take about 400 psi with a region insulated to take 400 degrees C, and have some centrifugal pumps set up to move gases around, and have a source for some hydrogen, you could set up a cracking/hydrogenation system and put out higher quality fuel.
#1081876 - 02/08/08 12:22 PM Re: Converting Used Motor Oil to Diesel [Re: oilyriser]
Loc: Texas
I am pretty much doing what is being done here... http://www.globalfinest.com/tech/
Except I don't have a plastic shredder and don't use plastics in my processor... Tell you the truth >> I think that if I filter the fuel to about 3-5 microns I shouldn't have any problems... People are running straight vegetable oil without much problem as long as the modify their delivery system to heat it... So a fuel that has the same consistence as diesel and well filtered should be a problem>>> I plan to put some lubricity additives in the fuel also.
As Far a heating systems... You can buy commercially sold heaters that run on waste motor oil and do a Very good job!... They are pretty comparable to traditional heating systems as far as initial setup costs but if you can get you fuel for free >> That is where you start to see you savings.
#1085016 - 02/12/08 10:56 PM Re: Converting Used Motor Oil to Diesel [Re: Mobile_Oilguy]
JHZR2 Offline
Loc: New Jersey
would you send me a sample? I'd like to put it through a GC-FID, GC-PFPD, and sulfur chemiluminescence test to see how the specs of this product really stack up to products ranging from marine gas oil to jet fuel.
Seriously... very interesting. Id love to test it from a chemistry standpoint, to see what the product really looks like chemically.
PM me if you'd like me to do this analysis.
Best,
JMH
Page 1 of 3 1 2 3 >
