2003 Ford Super Duty F-350
26,676 mi on unit
Shell Rotella 15W-40 CJ-4/SM
4,425 mi on oil
OEM air filter
Napa Gold oil filter
Previous fill was Mobil Delvac 1300 Super.
Make up oil was 0
Analysis by ANA
Fe 18
Cr 1
Pb 3
Cu 2
Sn 0
Al 4
Ni 0
Ag 0
Si 0
B 23
Na 4
Mg 114
Ca 1752
Ba 0
P 1251
Zn 1351
Ti 0
V 0
K 0
Fuel = 0 %
Soot/Solids= 0.2
Visc. @ 100 C = 10.56
Water .05 %
TBN = 6
"Gopher" Fire Dept. service with about 12 different drivers, lots of short trips and extensive idling-took over 6 mo for these miles to accumulate. Very happy with these numbers because I've seen how this truck is used!
Visc. has always been reduced to a 30 wt. by this mileage, with two different oils, without fuel present and any apparent negative impact on wear.
26,676 mi on unit
4,425 mi on oil
OEM air filter
Make up oil was 0
Analysis by ANA
Fe 18
Cr 1
Pb 3
Cu 2
Sn 0
Al 4
Ni 0
Ag 0
Si 0
B 23
Na 4
Mg 114
Ca 1752
Ba 0
P 1251
Zn 1351
Ti 0
V 0
K 0
Fuel = 0 %
Soot/Solids= 0.2
Water .05 %
TBN = 6
