2006 Dodge 2500 CTD - Rotella T 15w40
West Coast Florida
Enclosed are the results of UOA, The actual mix was Rotella T 3 gallons and one bottle SLOB, also note the prticle count was better as this is first check with B50 installed. Next sample will be without the K&N filter as I have installed WIX on last OC. Oil was changed to Valvoline 15w40.
Element: 5445 miles(B50) 3324 miles
Alum 6 4
Chrom 1 1
Iron 34 32
Lead 1 1
Copper 4 6
Tin 1 3
Moly 3 15
Mang 1 1
Silver 1 1
Potassium 39 20
Boron 22 42
Silicon 11 16
Sodium 3 4
Calcium 2349 2055
Magnesium 6 7
Phos 978 1065
Zinc 1136 1126
Barium 1 3
Visc SUS 90.7 89.3
CST Visc 18.15 17.8
Flash Point 435 410
Fuel Insoluble .3 .3
Particle count 16/15/12 19/16
Just as a reminder this truck was wrecked with a complete frame off completed in Aug07.
What are everyones thoughts?
The only thing that stands out to me is the alum, silicon, and the potaasium but that is due to break in. Make sure you post the #s on the particle count when you get them. What was damaged in the accident? The whole right side was replaced when my 05 was one year old, it took a pretty hard hit from a lady running a red light at 50 mph. These trucks are pretty tough except for the thin sheetmetal.
Silicon is probably related to K&N, I have changed this time. As for the wreck it was a complete frame off due to broken front ears on frame mounts, truck had less than 5k and Insurance paid. I plan on watching this for the next few oil changes and then go to annual checks, my biggest reason was to watch the particle count with the install of B50.
While I have nothing against the Amsoil version it is tough to beat less than $3 dollar bypass filter change, the B164 is about $1.50 more and I will be changing to them after my stock runs out. My overall cost was $150 +/-, but I went with all an fittings, stainless lines and billet brackets.
