I know there was some previous discussion on this subject but I want to get a clear understanding of what is the best and what is an acceptable oil to use in the 2006 Jeep Liberty diesel I recently acquired. The manual no longer only specifies Mobil 1 0W40 or 5W40, as it did for the 2005 model, but states:
Use SAE 0W-40 Synthetic Engine Oil that meets API Categories SM/CF, and the requirements
of DaimlerChrysler Material Standard MS-10725. If SAE 0W-40 is not available,
SAE 5W-40 Synthetic Engine Oil is acceptable.
I am using Mobil 1 0W40 the Euro oil. It is not easy to find and costs $6.50 a quart at local auto shop. I like the idea of the Mobil 1 Turbo Diesel Truck as it specifically addresses the issue that this engine has a turbo. I have historically liked Shell Rotella oil which I last used a lifetime ago when I had a 1966 Mercedes 200D. At the local COSTCO they have a Chevron DELO 5W40 synthetic and it is very reasonably priced.
Nobody lists compliance with DC Std MS-10725 but I have to believe that the regular Mobil 1 0W40 synth meets that requirement as it is what is used by the dealer.
I used to believe, in the 1966 era, that OK oil with frequent changes was the best way to go and it worked well for me. Now it looks like very long periods for oil changes (12K miles!) I wonder if a less expensive oil (the DELO) is OK and change it at 6K miles rather than a more expensive oil with less frequent oil changes? I do expect to work the Liberty a bit with towing a 2,000 to 3,000 lb trailer on vacation trips and have kayaks on top. Does that change the oil or change frequency recommendation? I live in Southern California and I do not expect to ever go where it is really cold, if that matters. I want to keep this Jeep a LONG time and don't want to be penny wise & dollar foolish. I want to set up a good maintenance routine.
