OP, what exact 1.6 Turbo DI engine? PSA EP6?
If concened about IVD a DI you want an oil with lowest possible evaporative loss and that commonly translates to low Noack and high flashpoint. Well established approvals like MB 229.51, BMW LL-04, VW 504 00 & 511 00 and Porsche C30 & C40 are reflecting that.
Dozens of discussions on that.
ACEA and Euro OEM spec oils.
bobistheoilguy.com
Hello everyone, I've been already asking if low saps oils are any good for the engines where they were not specifically demanded to be used by manufacture. The general answer I got on this forum is that since this is low saps oil, it will do a worse engine wear protection than ACEA A3/B4...
bobistheoilguy.com
I have just purchased a 2019 Buick with the 2.0 turbo motor. This is my first D.I. engine and have been reading about the problem with carbon build up on the intake valves. It appears to me that the oil from the EGR valve is what is causing the problem. I can not see anything else that would...
bobistheoilguy.com
Since I've noticed some members have repeatedly been searching for a dedicated list of Volkswagen approved engine oils and some tried to help by uploading PDF sheets, which inevitably suffer from getting outdated quite soon, I will post these links offcially provided by Volkswagen's "erWin"...
bobistheoilguy.com
LSPI in TDI engines? How's that? TSI engines?
