Your favorite engine sound
And a little OT footnote to the story. As with many modern aircraft, the EA-6's cockpit is pressurized with air that's bled off the engines' compressors. Nobody wanted to fly that particular jet for at least a month after our seagull incident. The entire thing reeked horribly (yeah, yeah, I know you're supposed to wear your O2 mask at all times...). Imagine a stench somewhere between badly burned meat and singed hair. I'm thinking that with the grinding action of the compressor blades, and the temps from compression, that poor bird was mostly incinerated before he even made it to the burner cans.
That must have been nasty...
I've cleaned up that mess, if you thought just the smell in the bleed air was nasty...
Surprisingly birds usually don't do much damage to the engine, they are considered "soft FOD"
Originally Posted By: JTK
An old wooden Chris-Craft (or the likes) with a flat-head or any full inboard marine for that matter as long as it's not an obnoxiously load twin engine job.
Joel
Agreed. Our 312 Inty (425HP) in our 22' Chris sounded sort of like an Indy Car on steroids when it hit north of 5K. The whole hull resonated with the song of the engine, it was almost a biblical event.
It had dual 3" straight pipes with flappers off a Shepherd on it.
My favourite engine sound is the EMD SD70ACe locomotive engines. They are a V16 2 cycle turbocharged engine producing 4300HP at 900 RPM. Love the sound of them when they notch the throttle up and the turbo starts spooling up!
Tom:
Very true. After we landed, one of the local A-6 squadrons was kind enough to have one of their guys scope the engine for us. Although there was blood splattered and smeared on the last couple feet of the duct, before the compressor face, and a few feathers caught in the inlet guide vanes, the engine itself sustained no detectable damage. I guess it just "digested" the poor guy, and incinerated any small pieces that made it through the compressor section.
The other factor contributing to our good fortune was that the J52 is a straight turbojet (not a turbofan, as is so common today). Compared to a TF, the blades are all short and stout, and pretty good at enduring reasonably survivable FOD -- like soft, juicy birds. . .
i might be a bit different than the norm but ones that i have always been fond of since childhood.
1693 Caterpillar. At idle they sound like theirs a midget inside the block trying to break out with a mini sledge. But its a sound that takes me back to childhood.
http://www.youtube.com/watch?v=AuvjHSWib0I
I tried to find a video of a 3408 cat under load really hauling the mail but i couldn't find one that did the sound justice.
12V71 Detroit diesel Doing work has to be an honorable mention.
http://www.youtube.com/watch?v=lfyIeO6zQBM
Originally Posted By: CivicFan
The quieter the engine, the more I like them. I thought I would like the menacing sounding engine and exhaust in our Z4 but after a some time you get tired of all the ruckus.
So, the Prius up to 20 mph would probably be the engine sound of my choice, i.e. none but the electric hum.
Blasphemy!
