I remember reading somewhere valvoline makes oils in different colors. Bottom of the oil pan area is showing leaks, but not sure where it is coming from. Car is at 149 K miles, but has not used HM oil before. Here is my plan to find out where the leak is coming from ...... Need comments....
Will the colored oil help, if i choose NOT to use the dye mentioned in the article. Note that engine compartment will be clean from wash anyways. Thanks for all comments and suggestions.
- Get engine area professionally pressure (water/steam) cleaned.
- Change oil (possibly with a colored high mileage oil)
- Follow instructions at Popular mechanics Finding Oil leaks and add dye.
- Check bottom of engine for every 500 miles, since leak is not dripping to floor.
