Yamaha Waverunner problem
Georgia
Took my 2008 Waverunner FX HO for a ride yesterday. Started and idles fine, but vibrates and minimal forward motion when give it gas. I checked the intake grate and its clear by feel.
Seems like it would be a drive issue. ?impeller? Could I limp it to the nearest boat ramp to bring it to dealer?
Thanks!
Does the engine rev up high when you give it gas? (= clogged impeller)
Or are the rev's limited? (=overheating-cooling water intake choked)
You need to look up at the wear ring and the impeller to see if you have something stuck between impeller and wear ring. I had a plastic margarine lid get sucked into mine and had the same symptoms.
Yes, that is a sign you have something stuck on the impeller. Do not try and remove this by reving the engine or you can bend the drive shaft.
Follow-up on the problem:
Brought it to dealer, who found a chunk of wood in the impeller/intake. They said it was just large enough to get stuck between blade and housing. Cleared it and ski is back to normal!
