Changed the oil in the xterra today. a 2001 with the 6 cyl, has used amsoil 10w30 and mobil 1 10w30 since 7000 miles. It has been given 4000 oci's with the mobil1 since it only has a 3.5 quart capacity. The oil has always been to the top level on the dipstick(terrible dipstick, thanks nissan), and not very dirty at all, brownish, but not bad at all when changed. So today, I checked the oil level as I always do, and its barely registering on the dipstick, and is black. Not the darkest black you can get, but close. Plenty of oil came out, Id estimate 3 quarts, so it wasnt very low. I did see some "sludge" on the drain plug, something else I have never seen previously.
So now I think I may have missed a change somehow, but even if I did, at wrost case Im at 8000 miles. My question is, to those that go 7500 miles on mobil 1, does your oil get black? I know color does not indicate if the oil is good or bad, and my engine differs from everyone elses, but I want to know if in a good running engine, does your oil go black at these intervals?
Seeing the condition of the oil at that interval, if it indeed was 8000 miles, would make me never go for that long again in this engine. If it wasnt 8000 miles, then I have problems I guess! Truck now had 64,500 miles.
Time for a UOA on this truck after 5000 miles I guess. Also time to start writing down the miles on the trucks when I do oil changes/maintence. I was always ok going by memory, but I guess Im losing it at 30. **** .
Thanks
Thanks
