Wrong muffler failed?
The last time I installed a cheap muffler I gave it a couple coats of flat black bbq paint and after it was hung I drilled a second drain hole in the bottom of the can at the lowest point. It had no noticeable exterior rust when I got rid of the car a few years later. I didn’t expect the muffler to last long so I didn’t use a clamp on the slip fit joint so it could be easily replaced, but the muffler lasted longer than the brake lines so the car had to go.
Yeah, I used to have mufflers replaced every two years also before stainless steel became the norm and every other corner had a muffler shop. Now all those muffler shops are gone.
You better hurry with Sears though, they're just down to 21 stores and they'll probably be gone next year. I think there's just one store left in Maryland.
https://brostocks.com/2021/11/20/how-many-sears-stores-are-left/
Sears Auto had stopped selling mufflers long before my penance there from 2005-2007
