The biggest source of resistance is the gap.......
The "flat" face of the copper plugs, especially when fresh, give you a nice sharp edge for the spark to jump from. The Iridium and Platinum plugs do not have the same sharp edges on them.
As copper plugs wear, that "edge" wears off, making the plugs more difficult to fire, since it now has to fire from a rounded surface.
+1, and the surface of all "copper" plugs are actually steel, not copper, and platinum and iridium plugs have the same copper cores internally, so there goes the resistance argument.
Anyhow, it is really the plug's sharpness and the gap that make the most difference. As the plug wear and the gap widen, your resistance goes all over.
The most important thing to the firing is actually how high of the voltage difference goes between the gap before the di-electric break down happen (aka firing). Too high it would cause a misfire once in a while, and too close of a gap will reduce the flame speed. If your car is that picky about firing voltage, your coil (which step up the voltage from the 12V) needs to be replaced.
