My kids 2002 Taurus (3.0L) ran low on water, but not to the point of boiling over. Found he had a very slow leak at the base of the water pump that slowly drained the coolant. He noticed the heater not working very well. So I decided to drive it to work one morning. The heater was dead cold and I noticed the temp gauge needle spiking up then coming back down. I turned around, drove it back home and found the coolant about 1 gallon low.
So I'm not sure, but as the coolant level slowly dropped would the heads have run exceptionally hot and would that hurt the oil? Should I change it immediately? The oil looks fine and the engine seems to run fine. I only had about 1k on the change...
