So I finally did it. Changed my oil for the first time on my own! After lurking on here, I was inspired haha But I'm glad I did it and looking forward to doing more! But now I have a problem..
The car is the 2.7L Sebring which I plan to keep for the next 4-5 years. OCI's of 5,000km, mostly dealer oil changes, but some jiffy lube type places (watched carefully). The previous Oil Change was done at a Lube Stop (130,000km on the odometer). I watched them throughout and they were actually very good. The even gave me a new oil drain plug.. for free! Said mine was the original, and is short, and that it should be changed. I requested to keep the old one.
As I changed the oil myself, I compared the plugs. I tried putting in the old one, went in smoothly, but it would not tighten at the end for some reason... it just kept "spinning". The new drain plug is definitely much longer, and might even be a single oversized plug (not sure). The threads on the pan seem as to be "coming off" as I discarded some metal pieces (or might be from using an oversized plug). The newer plug went in, with some extra effort (not much) and no leaks.
I actually don't have a problem right now... but want to avoid future problems, that being, having to replace the oil pan, which may get costly. After doing some reading online, I came across piggyback drain plugs, and actually bought one from Napa for under 5 bucks. It's a single oversized piggyback plug, but is short like the original plug (they didn't have longer ones).
Looking for opinions here... My thinking is, next oil change, try to install this Piggyback plug (this will be done by my mechanic... just in case there are issues). Hopefully it will go on with out any issues and therefore I will never have to damage the oil pan threads any further, as the internal screw will only be removed for oil changes in the future.
Does anyone have any experience with these Piggyback Plugs? Do they last? Do they leak in the future? Should I just continue using the newer plug from Lube Stop? Should I just get a mechanic to change my oil from now on.. just in case? I'd like to change the oil myself in the future, but I am worried about having problems with the drain plug.
Any comments/opinions appreciated...
