Okay, here is my concern on using both. I plan to put a 125 watt pan heater on oil pan for 12 litre oil capacity, then another one on my tranny fluid pan, again 125 watts. (I want to heat the tranny because this thing will not shift into overdrive for up to 1/2 hour driving on highway at full engine operating temp) Now my factory block heater is 6.5 amps or about 700 watts.
That is a lot of power draw, I expect about 10 amps on all three, I suppose a 15 amp breaker would take it? I guess the heater pads only need a couple hours too.
Any suggestions on options, I block heater absolutely needed?
Cyprs
