Wix WL10010 from Rockauto, used on my Caravan. Normal OCI for this filter was 10,000 KM (6200 miles). Oil used was Pennzoil Platinum. This filter was sitting in the bin from a few years ago.
I used one in my Rubicon, but they are the longest of the filters I measured (WIX, Mahle, Hastings, Mopar, and FRAM) and they tend to twist.
I did, I will dig them up and send them to you.Good to know. Did you record the differences in length of each of the filters?
@IndyFan may have some input on that one. I did not measure the Mopar that I had, but I do know that it twisted and it was only used for 800 miles when I changed it (factory fill and filter).Thanks a bunch for the detailed sizes of the filters. I wonder what size the mopar filters are?
The only Mopar I had was the one from the factory and it is long gone. It twisted more than the Frams and the M1 that I have run since. But it held together just fine, as did the others. No signs of compromise to the pleats or any other part of the filter.@IndyFan may have some input on that one. I did not measure the Mopar that I had, but I do know that it twisted and it was only used for 800 miles when I changed it (factory fill and filter).
Indyfan, so what is your preferred filter for the Pentastar?
My gripe about the M1 filters is the cost, so your $4 price tag eliminates that. You got a great deal for sure.My fav is the Fram Ultra. But I bought about 12 Mobil 1 filters on clearance at Walmart for 4 bucks each. While not as efficient as the Fram, I think they are still very good, so I´ll be running them for a good long time.
Lol, I could have gotten more, but I left some for others. With 12, though, that's probably 90k miles at 7.5k per OCI, which is what I think we'll be doing. They'll be at least 5k, but I think I'll go the distance which usually works out to about 7500.My gripe about the M1 filters is the cost, so your $4 price tag eliminates that. You got a great deal for sure.
I installed the new filter into the housing first then screwed on the cap... But everything I am finding now shows people popping the filter onto the cap first, then screwing it in. When I was removing it, the filter remained in the housing and did not come out with the cap, so I just did the install in reverse. Not sure if it matters?
