I bought a Camco kit to winterize my Volvo Penta I/O. The kit instructions says if the I/O has the pump in the outdrive that use the muffs otherwise use a Camco adapter (optional purchase) to connect the Camco kit with adapter to the sea water pump mounted on the engine.
I think the instructions are not quite correct. I think it's whether the water intake is in the outdrive or not. Not whether the sea water pump is in the outdrive.
