I have successfully (with analisis) a good .90 Ash 15W-40 and 20W-50 oils in Detroit engines. There are two main problems. Higher Ash content accumulates in the ports (have ports, not valves), and VI's tend to shear. I don't have the books with me at the moment, but there are specific shear tests for Detroit Diesels.
That being said, here is an explanation from Detroit Diesel:
"The use of a block heater or any other type of engine heating device is
recommended for engine start-up in cold weather. Once the engine reaches
the normal operating temperature, the ambient temperature has little effect
on the engine's internal temperature.
Detroit Diesel recommends the use of single grade viscosity oils in all two
cycle engines. Normally the recommended lubricating oil viscosity is SAE
40. In cold weather operation, if for any special reason or circumstance,
the use of a heating device is not possible, a single grade SAE 30 viscosity
oil can be used with a good probability that there will not be a hard
starting condition (please refer to publication 7SE270). Only as a last
resource, and with ambient tempartures below 0 degrees C, a multi-viscosity
oil may be used. The following indications must be considered:
1)- On Series 53, 71 and 92 engines running under long cold weather
conditions below 0 degrees C, if it is not possible to use a SAE 40 oil, an
engine heating device and/or a SAE 30 oil, then 15W-40 oils are the only
multi-viscosity oils to be considered.
2)- No other multi-viscosity oil are recommended for two cycle Detroit
Diesel engines regardless of the operating conditions.
3)- The use of multi-viscosity oils is considered an exception for special
operating conditions only. The use of these lubricating oils in two cycle
engines under normal operating conditions, variable weather conditions or
ambient temperatures above 0 degrees C, will not provide satisfactory
service results.
3)- Multi-viscosity oils should not be used under any circumstances on
Series 149 engines or in any two cycle marine application engines.
4)- Detroit Diesel Corporation recommends the use of lubricating oils, fuel
and filters as per publication 7SE270. The use of these products is the
responsability of the supplier and the end user.
WT
[email protected]"
