What I don’t like in Outlander PHEV is that it starts engine for heat very early. Like 60-62f (climate control is set on auto for 70-72. I know that if AC has 10 or more degree diff for ambient vs your target temp, it will enable recirc, so maybe same logic goes for hrat and it start ICE). It will start it even if I preheated cabin for some time, while plugged into charger, and even if I have EV mode enabled. Maybe my battery is getting weak…( 14 miles lately vs 22 per spec). I Volt you could set it not to start engine down to like 28F if I recall correctly…
Volt won't start engine for cold unless it's cold enough to get to the selected ERDTT temp or if battery pack is weak.
