Will these copper washers fit 98 lesabre?
stamford, CT
That's the link. The drain plug gaskets I've been using,were rubber, Dorman product.but they have an extra circle in them,that makes the seal. I want too try copper washers! These are smooth...would they work?
Perhaps hardware store is ok too use?
1676271732360.jpgFor reffetrence,this black one is what I've been using all along.could I use the copper ones instead!?
I would just get a new drain plug with a matching washer at your Buick dealer. It will likely outlast your old Lesabre.
I was curious. I always replace the rubber gasket. $1.99 from advance auto. Fel to is rubber brown $2.49. I use a pen too pry the old one off,and put new rubber one on like twice a year sometimes one,I do an oil change..3700-4000 miles by then.depends.
Last time I used a copper washer,from local hardware store was way back in 1995. I had a 1985 Isuzu I mark hatchback. Doing an oil change driveway that spring I used a copper washer on plug.no leaks at all! So thought maybe is it possible on the LeSabre? Like the pic listed in post..the copper ones,think they're work?
i use the copper washers on All my cars, no problems. copper washers is what came off when I bought it
