Why would you ever want to run 10W-30 over 5W-30?
I've always wondered this and never have figured it out.
Assuming you keep your RPMs below 2,500 until the car warms up, what would the point in running 10W-30 over 5W-30? If anything I would think you would want to run 5W-30 over the other to get oil to the valvetrain faster.
When up to operating temps when you would go wide open throttle, both oils are the same weight.
The winter rating is about cranking and pumpability, not flow. Such a common misconception.
And it’s highly dependent on temperature. Depending on the temperature there’s no guarantee any particular oil with a 5W winter rating flows any better than one with a 10W rating. Again not that flow really matters here.
All else being equal
the 10W-30 has less viscosity modifiers which are not 100% shear stable and cause deposits
the 10W-30 is less volatile
the 10W-30 has a higher base oil viscosity mix, which timing chains love.
If you can get a synthetic 10W-30 and the temperatures in your area are high enough to use it (above 0°F at all times), I see no reason to use 5W-30
What about 5W-40 instead of 5W-30? I run Rotella T6 and they have 10W-30 and 5W-40. (not sure why they don't have 10W-40)
except all else is likely not equal.
I don’t see any practical reason except for improved shear stability. If you run extended oil change intervals….. But frequent oil change is always a good thing.
depends on the appication. When hot, the 5W-40 will protect better, but expect higher volatility and more viscosity modifier
Man I got a long way to go when it comes to learning oil.
Ok so volatility, you are saying I will lose more oil with the 5W-40 over 10W-30? If so I have no concern here because I check my oil weekly or bi-weekly to make sure the level and color is fine.
Viscosity modifier...I have no idea what that means.
volatility could lead to intake tract deposits, but to be fair I consider it more of an indication of the base oils used and what those could or couldn't do.
viscosity modifiers are added to make oil less thin than they would be when hot. Strip the viscosity modifier from a 5W-40 and you likely end up with a 0W-20.
I used to run Chevron Delo XLE 10w30 in my Civic years ago, you could get it at Walmart for $12-$13 jug back then. I experienced the lowest consumption when running that oil. Sometimes during winter it can drop into the teens but typically doesn't stay there long but never had an issue.
