Here’s why I run synthetic:
My car takes 3.5 qts. Mobil 1 is ~$20 for 5 qts at wally world. ~$6 for WIX filter. My oil change cost is ~$20 b/c I only use part of the 5 qts.
I change my oil at 5k miles, b/c my car is a 1993 and the recommended is 3750/7500 severe/normal. I know I have extra protection doing this and that my engine internals are clean w/o any flushes or additives needed.
Now for people who say that today’s dino oils are good enough, that’s fine. I enjoy a greater piece of mind knowing I’m using one of the top oils available. My car gets 32 MPG (that’s conservative, also) and over that 5k OCI, I will burn ~156 gallons @32MPG. At $2.40 a gallon (also conservative for this part of CA) I will spend $375 on gas during this period. So the cost of my oil change is roughly 1/20 or 5% that of my gas. To me it just makes sound sense. Plus the M1 is probably helping me get that good gas mileage.
Now for those with larger sumps, maybe synthetic is too much of a price difference, although if your car is newer, you can likely go longer OCIs. Once you factor in the gas money you spend (especially since a larger sump, means larger engine and you won’t be getting 30+ MPG) it really seems like the extra protection and cleaning ability is always worth it. Just my $.02.
