SAE J300 doesn't specify negative numbers. But if it did, the cold flow characteristics of a -20w would be out of this world!!(assuming a linear slope of the j300 numbering system extended into negative numbers some day). One wonders how useful this would be. I can see using 0w30 in freezing weather, but once you start moving to 0w-40/50 oils you start to see other compromises(sheer, base stock availability, cost). Id only use it if I were operating my vehicle in, say, -50 temps. At that point, I'd imagine other issues would manifest on my poor cold car.
