Originally Posted By: SonofJoe
There is nothing stopping anyone selling ILSAC GF-5 oils in Europe.
However it's probably fair to say that historically, European OEMs have not liked the US style of formulating engine oils for a variety of reasons.
First, they are regarded as being too shearable. The 55 SSI OCP VIIs that are so common in the US are unheard of here in Europe where more shear-stable, 22 SSI (and often lower) VIIs are the norm.
Secondly, they are regarded as being far too volatile. This is less true now than it was 20 years ago but you can still find US oils with a Noack just shy of 15% whereas I think you would struggle to find a European PCMO with a Noack much greater than 12%.
Thirdly, US oils are regarded as being very aggressive to seal elastomers. This definitely was true right up until the advent of GF-5.
Fourth (and this is just one for industry folk), the way ILSAC builds fuel economy performance into its engine oils is frankly completely daft! It forces you to bend the oil out of shape such that it's simultaneously too volatile, contains too much VII (of the wrong type) and contains friction modifiers which in reality do bugger all to reduce fuel consumption.
Finally US oils aren't particularly good in PCDO applications. If you're just after an oil for a gasoline engine, this shouldn't matter but traditionally, all Euro motor oils are dual-function.
Hope that helps some...
PS - not all of us drive like maniacs!
This is very true. Yep things are changing slowly because of forced hands, but typically that's right on.
