FIAT recommends GL-1 90 weight gear oil in the transmission. Somewhat hard to find at autopart stores but can be sourced from places like Tractor Supply because it is used in Ford tractors. Usually in 5 gallon buckets but not very expensive.
http://www.tractorsupply.com/en/store/travellerreg%3B-ford-tractor-all-mineral-90-transmission-fluid-2-gal
I *think* this is GL-1. I've heard GL-1 is a mineral oil and the bottle says mineral oil but nothing about GL-1. What kills me is manufacturers don't always put the full name on their products. This company is calling it SAE 90. So is it the same as GL-1 90?
I've owned these cars for over 20 years and the word on the street is if you use an EP differential oil (e.g GL-5 75W90) it will destroy the brass syncronizers.
I have heard that EP gear oil (the additives) will destroy wet clutches in motorbikes in no time.
So what's in EP that is OK for a ring and pinion differential but not a transmission? Will the additives truely "eat" the brass syncronizers in a manual gearbox?
By the way. Some people like to run 20W50 (for easier wintertime shifting) in their Fiat transmissions however I tried this in my Yugo and 3rd would grind when I shifted from 2nd to 3rd. I went back to GL-1 90 and no more grinding. I fould bits of brass in the oil I drained out of it.
