This is exactly what I was talking about in my post. He just went 2 rounds with the ghost of Mike Tyson. Some people are so invested in a particular viewpoint, that, when coupled with the lack will or ability to properly understand a counter-point, they immediately misconstrue it as an attack.
You brought up a great example with Ford and the Coyote and the BOSS 302. They did the same thing with the Track Pack version of the GT, spec'd 5w-50 for the same engine that spec'd 5w-20 in the "regular" GT.
FCA spec's 0w-40 in the 6.4L and 6.2L but 5w-20 in the 5.7L. The 6.4's (and especially the 6.2L) have higher power density and, being lower production, won't have much impact on CAFE. But construction-wise, the engines are all very similar and the 6.4L and 5.7L have the same clearances.
The paper we discussed from Honda years ago where they talked about the push to thinner oils resulting in more focus on additives that target increased operation in boundary/mixed vs hydrodynamic where you are working to control/limit wear, something not required in hydrodynamic, is another example. That was for 0w-12 and 0w-8 IIRC, with HTHS dropping below 2. As long as the wear rate was sufficiently controlled, it was acceptable (I believe they actually used the word acceptable in the paper) because it wasn't perceptible to the end user and still allowed the engine to achieve an appropriate lifespan. Of course one of the other issues was Noack that was wickedly high and an exception required to be made, but that's beyond the scope of this discussion.
Some screenshots from an SwRI research paper:
