I wasn't picking on you. There are people out there that need an oil with a higher HTHS but I'm talking about the average Joe. Where you get on my nerve is your constant beating on this subject that we all need the protection of MOFT just in case which simply isn't true.
See, this is what I was talking about reading between the lines. I just post the reasons why thicker oil gives more protection due to increase MOFT. I have NEVER said people better use thicker oil "
just in case" or your engine is going to be destroyed - that's what I say I do. I use a bit thicker than recommended for the reasons I've stated, and have said many times that people can make up their own minds based on the reasoning. If they want to run thinner oil, then good for them ... it's not my vehicle so I could care less that people do. So I'd appreciate it if you knock off this misconception that people taking about using thicker oil is a message that going thinner is "bad" and that everyone should do it, because that's not really the overall message. People can make up their own mind based on what they read and research on the subject (there is lots of info out there).
I've been reading these threads for quite some time and haven't seen "all these threads". What I have read is going thinner is not a recommend blank statement. I would never use a thinner oil that the manufacturer hasn't approved or back spec'd. But making a blank statement you should go up a grade "just in case" is ridiculous for engines that are approved for the said grade. I have also read, by people in the know, That going up or down one grade without any harm whatsoever.
Well, I've never made a statement that "
going thinner is not recommended blanket statement". Go back and read carefully. I've said many times it depends on the use conditions, but I also say that
for me based on reasons given, I go a bit thicker because I like headroom ... so what? That's a "just in case" for ME based on the reasons I've concluded to do so. Stop reading between the lines. Why would you or anyone else care that I want to do that with my vehicle? You seem to be trying to use me as a "thickie target" because you can't seem to accept the fact that thicker oil does provide better MOFT and protection between moving parts. Don't attack me or others that say the same thing (that more MOFT gives better headroom) because they don't see it the same way you do, and should just use what's "recommended" by the manufacture.
I don't think it's "bad" to up one grade and it will harm nothing. I'm using one grade lower in three of my vehicles that were designed for 5 and 10w-30. But all three were back spec'd by the factory. I surely would not if they were not.
CAFE: I wish everyone would stop blaming CAFE for thinner oils. It was actually the manufacturers (originally Ford and Honda) that requested the use and recommendation for the use of thinner oil (5w-20) in response to the EPA's new, at the time, fuel economy requirements.
Of course going up a grade (or even two) isn't going to harm anything - nobody has any proof whatsoever that it will. Only way it might be "bad" is if someone used the wrong "W" rating in cold weather start-ups. I'm sure everyone could also go one grade lower than specified and they won't have any noticeable engine "harm" ... but it would take major harm for anyone sitting in the drivers seat to really tell. But going one grade lower could result in more wear, or maybe harm
in some engines - I think Ford bumped back up to 5W-30 in the Coyote for a reason, and most likely based on wear and harm in some use conditions. Manufacturers who make high performance, high HP engines need to look at worse case use conditions by the type of people who buy those vehicles. Guys driving Mustangs around are going to beat the engine pretty good at times. That was the reason the Boss 302 came filled with 5W-50 from the factory - Ford knew those cars were not going to be babied.
CAFE doesn't dictate to the manufactures that they must use thinner and thinner oil .... but CAFE is indirectly a factor because the car manufacturers have CAFE targets (same as your bolded fuel economy requirements text above) to meet, and using thinner oil is one way (among many other ways) to try and hit the every increasing target. It costs them money if they can't meet the targets. If there was no CAFE I highly doubt many of these engines specifying xW-16 or xW-20 would be running that viscosity. Since Ford changed the viscosity back to 5W-30 on the Coyote in the F-150 and Mustang they must have made it up someplace else to meet CAFE, or took a ding on meeting the targets and made it up on the MSRP window sticker, lol.
