> Good point, MAYBE your right... Any
> conclusive evidence that shows it
> does???? So far, I have not heard
> anyone conclusivly state that YES,
> Maxlife has resolve my seal leaks
> unlike auto rx and neutra 131. Care
> to share with us the many that have?
Bob, MaxLife is not intended to be an Auto-Rx replacement. You know that, and hopefully most everyone on this forum knows that. MaxLife may serve a purpose. It may provide a prophylactic benefit over the course of continual use. At $0.20/qt over their All-Climate conventional oil, it may not be a bad deal. Who knows? Oil analysis will only tell you so much and I'm sure that you and the good folks at Schaeffer's do not know about Valvoline's research and empirical data. People have a tendency to work within their framework and not venture out. MaxLife may be more than the sum of it's parts.
> Don't some syth's carry a group V
> ester that you state swell seals?
> Not heard of any full synth conditioning
> seals and reducing oil leaks, but just
> the opposite occurs mostly in older
> vehicles.
Bob, most synths containing esters have ingredients to counter the swelling, like PAO in Mobil 1. And who knows... 9% esters may be the magic number to provide a benefit without leaks. You don't know. I don't know. Only time will tell.
> Why would the detergency in maxlife be
> so low in comparision to the full synths?
> You'd think that you'd have to clean the
> seals and surfaces prior to conditioning
> it would it?
Bob, detergents are relatively inexpensive. If it was that easy, I'm sure that they would have added them. Again, you and I don't know their goals, the science, the empirical data, and the long-term results.
> From the analysis and my little experiment
> I saw just the opposite, the synth's cleaned
> much better, maxlife failed miserably in
> comparision.
Bob, none of your experiments characterize, emulate or even approximate the engine environment.
> Auto rx and neutra 131 both have
> cleaning abilities that is needed to
> accomplish this.
I agree if it is desirable to do so, quickly. That was not Valvoline's mission.
> I stand by my opinion as it is and
> strongly disagree that maxlife
> conditions seals no better than any
> other oil and that it is a marketing
> ploy for their product
You are entitled to your opinion.
Maybe MaxLife conditions seals as well as any other ester-based synthetic on the long run. But for $0.20 over the price of conventional oil, it's not a mere marketing ploy. It's called value.
