Expanding on others' comments with some articles I've kept, multi-viscocity oils are created by adding polymers to a light base (5w, 10w, 20w), which prevent the oil from thinning as much as it warms up. At cold temperatures the polymers are coiled up and allow the oil to flow as their low numbers indicate. As the oil warms up the polymers unwind into long chains that prevent the oil from thinning as it normally would. Always use a multi grade with the narrowest span of viscosity that is appropriate for the temperatures you will encounter. In winter base your decision on the lowest temperatures you will encounter, and in summer on the highest temps you'll encounter. Polymers can shear and burn, forming deposits that can cause ring sticking and other problems. Ther greater the spread (such as with 5w-50), the more polymers that are required, and fewer polymers are better for all engines. The wide viscosity range oils, in general, are more prone to viscosity and thermal breakdown due to higher polymer content. It is the oil that lubricates, not the additives (except for anti-wear and anti-friction compounds such as zinc and moly). Oils that can do their job with the fewest additives are best.
[ November 15, 2003, 07:10 PM: Message edited by: TC ]
