I recently replaced my Honda's distributor cap and rotor. The rotor (#3) is held to the shaft with a 5x12mm screw (#12):
When I installed the rotor, I tore up the screw's little phillips head, and re-installed it using Vise-Grips. Since I've read several accounts of this screw coming loose and wrecking the distributor, I decided to get a fresh screw and use a little Loctite on it.
The factory service manual specifies that the screw is to be diamagnetic (i.e. non-magnetic, vs. "ferromagnetic" like ordinary steel). I went to the best local hardware store, and got a stainless screw, but they only stocked Allen head screws in that material and size.
I wasn't sure that the larger Allen head would clear the splash shield as the rotor turned, so I went to the dealer to buy the Genuine Honda Screw(*). I picked it off the parts diagram on their computer. It turned out to be very much ferromagnetic.
When I installed the new screw, I realized that the old one was also ferromagnetic. It's always run fine, as far as I can tell, so I guess it doesn't really matter. But I'm left wondering... why the heck did Honda spec a diamagnetic screw in the first place?
The rotor itself is plastic with non-magnetic contacts, but the sleeve in the center, through which the screw passes, is ferromagnetic. So it's not really clear to me why adding a ferromagnetic screw would really make a difference (and, apparently, it doesn't).
(*) This term is sometimes used with a meaning not related to fasteners, but only the literal definition applies here. The screw only set me back $0.52, tax included.
