Patman
Staff member
quote:
Originally posted by 96' maxima man:
Hey: I just joined the group! I have a 96 nissan maxima, bought three weeks ago from original owner with all documented oil changes every 3k mile, currently has 115 k miles,looking for suggestions on whether to go to synthentic for the best protection and if so proper procedure in switching over. Thanks Guys!
There's lots of good info on this forum that will answer all your questions above, just poke around and read up and you'll learn everything you need to know in order to make an educated decision. There is no "best oil" out there, but there sure are a lot of good ones. You can go wrong choosing an oil from the following: Schaeffers, Redline, Amsoil, Mobil 1, Royal Purple, and many more.
More than likely you can switch straight over to synthetic with no worries, but if you feel the engine might be slightly dirty inside, put a bottle of Auto-rx in first to clean it out. That product is found here: www.auto-rx.com Many of us have used it with great results. It helps to have a clean slate inside the engine when starting with a new oil.
