Originally Posted By: sparkplug
Personally unless your running a modded car a CAI does nothing. Untuned it really does nothing, might increase the mpg a little. On my Jeep I installed a 2.5 inch catback and a K&N filter. Gas mileage went from 17 mpg to 19 mpg. Hand calculated over a 2400 mile trip. Recently I've been getting 20 mpg. But I give the credit to summer blend gas.
Most of the time unless you're running a Speed Density system, there is No Tuning needed. I like my CIA because it draws in cold air from the grille (not from the little area behind the headlight), makes a nice tool tray, Looks cool, and is LOUD as [censored]
It's now sporting an Amsoil EA filter too
(08 Summer Pic)
Speed Density only requires tuning if you've made a cam or injector change. A CAI would do nothing to confuse it.
I've been told on some older systems with speed density, exhaust and intake changes require tuning.
If you think how the system works (MAP sensor) the only thing that is going to affect vaccum (how it determines fuel delivery) is going to be a cam swap.
Injector size changing, or forced induction are other obvious reasons to require tuning.
I had a massive CAI and full exhaust on my '87 GT. Converted it to MAF when I did heads/cam/intake because it was necessary. If I had left the stock HO cam, or had gone with a cam that had an SD-friendly profile, I would not have had to convert it.
SD is more adaptive than many give it credit for.
