Which type of oil do you use on a regular basis?
Michigan
Exotic/Expensive Syn Brand name Syn Off Brand Syn Name brand Semi Syn blend Off Brand Semi Syn blend Brand name Conventional Off Brand Conventional I use name brand Syn oil in all my rides.
PA
Where's the option for "solid product that meets all manufacturer's specs for warranty purposes"?
ZZman
Michigan
That could be any of the above. But what do you use regularly?
Chicago IL
Group III syn with 5k to 8k intervals, weather and usage dependent. Regularly put 150k to 300k on my vehicles. Used a Group IV Diesel engine oil on my TDI, rest in peace.
Champlain/Hudson Valley
The proper BRAND NAME SYNTHETIC or BRAND NAME CONVENTIONAL purchased on sale. I have one last jug of Texaco Havoline 5W-30 conv. in standby for whomever needs it.
Central NY
Supertech synthetic is probably my most common. But also did buy a bunch of 15w40 conventional supertech for my 1995 Wrangler for both transmission aM41l8ocksnd engine
NC
Whatever is on sale... Generally a name brand Synthetic. Although I have a few quarts of $1 GTX high mileage that I bought at Dollar General on clearance. None of my cars have any specific oil requirements other than API SN. Even thought the '01 Civic and CR-V spec 5w-20, I've ran 5w-30 with no ill effects so I can use the same weight for everything. I'm thinking of narrowing it down to one brand. It seems I use Pennzoil more than anything judging by the old jugs with used oil in my shed. I got hooked on it when PUP was $10 for a 5 quart jug at Walmart before the GTL rollout. If I stay with one brand, I feel a bit better about combining leftover oil into one jug for an extra oil change.
Bud
$50 Site Donor 2023
Texas
Mobil 1 when I get it on sale at Costco and tie the purchase in with a rebate.
ST Augustine, FL
M1 0W40 in a 220K v-6 2003 4Runner w/Frantz bypass filter QSUD 0W-20 2010 RAV4 2.5L w/ Baldwin bypass filter QSUD 5W-30 2016 NV2500 V-6 20K dealer synthetic oil 2017 RAV4 11K (when I can get the dealer to follow instructions and change the oil at less than 10K mile increments). QSUD 5W-30 2007 4.2L 2007 F150 XL 169K
ROCHESTER, NY
I use everything on sale/discounted/discontinued/rebate in dino or syn, 5W20 or 5W30.(5W30 is my go to oil). Now & again if I need something for a particular car like my OPE or my Firebird FORMULA in my sig, I'll buy that. But, even the Firebird I use 5W30 HM. And yes, I do alternate between the 5W20 & 5W30 dino & syn for summer & winter oils, depending on what I have in my stash and how I arrange them for their intended use.
Brand name synthetic. Valvoline is the go to brand for me at this moment.
Ontario, Canada
Liqui Moly 10W-60 in the M3. Not sure if it is exotic or not but surely expensive. For all the other cars. I just stick with whatever the cheapest syn or conventional depending on my $ per litre benchmark. Sometimes the brand name can be cheaper than the off brand.
