Which type of antifreeze
Missouri
Brother has a built 580 HP LS3 and is being told to run green antifreeze in it. Going in a 67 Camaro. Opinions on this ? I would run the red, just because. THANKS !
If it still has the original radiator, definitely stick to green silicate coolant
Otherwise, either green, G05, Peak Global Lifetime, or Peak 10x
GM had lots of trouble with Dexcool/Deathcool when they first started using it because the rest of the cooling system wasn't compatible with it. There's no way in hell a cooling system from the 60s is compatible with Deathcool.
Green, my favorite. ;)
No it's all new Alum. radiator, but i don't know what kind of heater core it has. I know he just installed the new late model A/C compressor along with everything that goes with it.
If it's a vintage air system it should have an aluminum core. You can use a long life coolant. If it's an old copper core you must use conventional green
