Time for new Struts on my 2020 Frontier. I do have extended warranty, however I can’t be down a week without the truck. It’s between these two.
Monroe or Gabriel
Monroe or Gabriel
Monroe or Gabriel
There are a lot of things that can cause what you describe, but struts are not high on the list. Are you sure the sway bar hardware and control arm bushings are in order?Mine sounds like the front end is falling apart over bumps. Checked everything out and no issues so I believe it’s the strut mounts, however I don’t have the strut compressor here. Truck rides like a truck.
Monroe or Gabriel
Yes I have been all under the truck checking. I will be pulling bumper off soon to check all bolts from the engine install next. I am getting cupping if I don’t rotate regularly and a vibration on certain roads, so I know that it’s time for struts anyway. I am ordering sway bar links today just cause they are stiff and not moving freely.There are a lot of things that can cause what you describe, but struts are not high on the list. Are you sure the sway bar hardware and control arm bushings are in order?
Not on extended warranty. When I was talking to the service writer she acted like I voided my extended warranty cause I do deliveries. She knows this cause I have delivered there.Do they not give a loaner? I hate how stiff and hard riding almost all aftermarket shocks are.
None.Time for new Struts on my 2020 Frontier. I do have extended warranty, however I can’t be down a week without the truck. It’s between these two.
Monroe or Gabriel
100% this.There are a lot of things that can cause what you describe, but struts are not high on the list. Are you sure the sway bar hardware and control arm bushings are in order?
Gabriel has worked well for me..Time for new Struts on my 2020 Frontier. I do have extended warranty, however I can’t be down a week without the truck. It’s between these two.
Monroe or Gabriel
I don’t either. I’ll remove the struts and take them to the shop and pay to have the new struts put in. The shop quoted me $100, which is well worth it.Mine sounds like the front end is falling apart over bumps. Checked everything out and no issues so I believe it’s the strut mounts, however I don’t have the strut compressor here. Truck rides like a truck.
Typically that’s due to crap springs. I used ready struts and then swapped in the Oem spring later and that fixed the issue. Why a company can’t make a decent whole unit is beyond me. It’s almost like they go out of their way to sell you garbage knowing what the results would be. Mando is probably the only ready strut that’s decent. And I use the word decent very loosely.Do they not give a loaner? I hate how stiff and hard riding almost all aftermarket shocks are.
