All ATFs are good. I don't see any 'regular' ATF as better or worse than any other.
You don't need any additives with your ATF.
If anything, add additional cooling and filtration.
And, if you don't have a drain plug, when the pan comes off for the filter change, install a drain plug kit. Regular drains/refills will do much to extend the life of the transmission.
