Which oil for 2003 Silverado 6.0L?
New to the forum
I have a 2003 Chevy Silverado LL LQ9 6.0 with 203k miles. 4l80e AWD. Has kooks long tube headers/full exhaust. Truck runs great. No oil loss between services. Oil pan is very lightly wet but not dripping. Oil pressure is 35psi at warm idle with current Mobil 1 High Mileage 5w30. I live in Alaska where it gets -40F give or take in winter and 80F give or take in summer. Truck is daily driver and idles a bit in winter and summer occasionally does some short wot pulls. I've looked and looked and get tons of conflicting info on what oil I should use. Should i use the Mobil 1 High Mileage Full Synthetic 5w30 or change to something like Mobil 1 FS 0W-40 for cold factor and summer pulls? Gets oil changed late fall and early spring. I'm sure I am over thinking it lol.
Thanks
And Bob is your uncle. Unless you want to go to 0W-X for the -40F cranking. If you've had no problems with Winter starts, there's no need to change to a 0W-30/40 and if you're not consuming oil, no need for the -40 as a bandaid.
Maybe consider the current darling Valvoline Restore and Protect 5W-30 if you do have consumption to see if it's dirty rings that can be cleaned up.
Mobil 1 0w-40 would be my pick. i run HPL 5w-40 in my 6.0 in Texas. keep the oil changed and that 6.0 will go on forever. i have 247k miles and 12,000 engine hours. still runs like a top and drive it everywhere.
  • Like
Reactions: 4wd
I have a 2008 6.0 closing in on 300,000 miles. Runs well. An oil analysis reveals some cam bearing wear which is normal. I went to a 5W40 for the summer but for cold weather in Alaska I would use a 0W40. What I actually do is run 0W30 in the winter and 5W40 in the summer.
