which oil viscosity recommended for focus in Eur
I am honestly just curious. Here in the US 5w2p is king but what would be the most used inna 2014 focus over yonder? Thanks all.
JHZR2
Staff member
New Jersey
Have you tried a viscosity recommendation took from a major overseas supplier? Mobil'so uk or German sites may be a good starting point. Google translate is your friend. I suspect higher, maybe 30 wt oil, with some tasks for 40 and 50wt. But if the engines are different, it is moot.
Germany
For all the new ecoboost gasoline car engines Ford Europe specs wss-m2c948-b 5w20. Back spec'd with the wss-m2c913-a thru d 5w30 except some performance engines
Kendall, FL
Different fuel, different road conditions and oci mandates. Not applicable as mentioned before.
Maryland
Europe is big. Probably 10W40 in London, UK and 5W40 or 0W40 in Kazan, RU. Liqui Moly in both cases. One thing: are you asking about Euro Focus in US or about which oils would I use in Europe? I answered on the second question. Here, in the US, I would still avoid such a silliness as 0W20 or 5W20 oils.
