Which oil for Suburban?
Girard, Ill
Which oil would you use in an 04 Chevy Suburban with the 5.3 L engine? I will not be pulling any trailers. I use amsoil in my corvette and Mobil 1 in my S10. Any advantage to either in my suburban?
I would use a 10 W30 in either Mobil 1 or Amsoil.
Used both and two Suburbans have > 300,000 miles on them, no engine work.
Molakule, are your suburbans the 5.3l or the older 5.7l? I just picked up a 2001 w/5.3l and 45,000 miles. I'm doing an auto-rx now and plan to use Mobil 1 5w30 @ 5000 mile OCI. I REALLY want 200k+ outta this rig.
Used to own a 5.7L Tahoe and when using the recommended 5w30 it would burn 1qt ever 2-3k synthetic or reg, but moving to 10w30 didnt seem to burn any.
300,000 miles on a American vehicle!!!! Don't tell the foregin lovers that!
Have you guys had to replace the transmission at all? Also how are your Ball joints and tire rod ends/suspention doing at this kind of mileage?
quote:
My take is regardless of what oil you use, "there is no solution like dilution". So, while I use synthetic oils, I do not adhere to the notion that one can go b'zillions of miles between OCI. IMHO, new vehicles are just too expensive to worry about extending the life of an oil change.
Your vehicle has the aluminum block engine. I do not know how, if at all, this will change reliability over the older cast iron block 350's.
I have an Avalanche with the same engine. Since it's warm here in Northern Calif., I intend to run Kendall GT-1 full synthetic 10w30, with OCI of 3K miles, and Baldwin oil filters.
Best of luck.
Bob W.
I have a friend with a older suberban with the 350 5.7 with 375,000 miles never touched. Well he has always used a good 15w40 in it and he will only use a quart about every 2,000 miles. The previous owner used wolf's head 15w40 in it and he didn't have any problems ether.
Yeah, twice. Once at around 150K and again at 320K. Not sure about the ball joints, original I believe but we put more springs in the rear. Oh, and the diff blew at 180K. This vehicle pulled more loads then the law should allow.
Yes, about the same scenario as EmbarkChief.
I have had 2 transmission rebuilds/replacements on each. I replaced U-Joints once on each Burb with zerk fittings. Had a diffy ring gear tooth failure on the '92 at 245,000+ miles.
As with the Chief, I have hauled loads of wood across country with both, which really puts a strain on the 700R4's. But I pull 2 tons of fire-wood with them at 75+ mph for up to 400 miles at a time, however, the transmissions lasted up to 185,000 miles before rebuild/replacement. I find the GoodWrench factory replacements to be better than the rebuilds.
No tie rod ends or spring replacements on either. Same original PS pumps. Replaced shocks every 25,000 miles because some of the roads are gravel.
