Hi,
just got our new car : brand new Suzuki Vitara MY2019, 1.0 Boosterjet (111hp), Privilege trim, glossy white. I'll post a thread on it later.
It's a car on which we'll put not much miles on it and plan to keep it "forever". So, I'm keen on spending money on top-tier motor oils and alike.
When I lookup recommendations from Castrol or Motul, basically even a 10W40 A3/B4 oil is allowed. I'm OK with using that kind of viscosities, since it will not be a daily driver or short tripper. I'm basically concerned with carbon deposit on valves, and LSPI.
How to prevent carbon deposits? Should I use a valve cleaner spray on a regular basis to keep the build-up away ?
Does oil got anything to do with it ? If so, should I install an oil catch can (but should be removable whenever the car should go to the dealer to warranty work or annual service, it will go only 2 times if all goes well) to dry up the PCV product ?
Suggest whatever euro oil you would put in there for annual OCI. I can surely have those over-the-counter brands: Motul, Castrol, Total, Shell, Valvoline, Liqui Moly, Bardahl. Should I stick with ACEA A3/B4, or go API SN Plus / Dexos1 gen2, or ACEA A5... I just want the best protection for the engine and turbo, and the less valve deposit problems.
I know this topic went up a great number of times, but we've still got a little to no tech details on this engine.
