- Messages
- 146
- Location
- Irvine or Berkeley, Ca
I posted earlier about what oil to use in my car which is a daily driven and tracked 2001 Toyota Celica GT-S. I have learned that my car at the track reaches almost 300* F oil temp. This has prompted me to search for oil coolers. There are only two types available for my car. Both are Sandwhich type coolers. One is the TRD oil cooler which was originally designed as an OEM part, but removed before finalization of the design of the car. It is a oil/water oil cooler that uses the engine coolant to cool the oil. A friend of mine has seen oil temps of 220* on the track with this oil cooler. This cooler is usually around $300 and is somewhat hard to find as it rarley imported to the US. The other type of oil cooler is is a Perma Cool/Cool-tek oil cooler which runs for approx. $130. I only know of one Celica wit this kit and he has not tracked his car. This kit is also a sandwich type cooler, but instead of using the engine coolant to cool the oil it has a small radiator mounted in the front of the car to cool the oil. Oh also my car's engine has oil jets that cool the underside of the piston crown. I am sure that is one of the reasons of the high temperatures.
Here are some links to the different oil coolers:
Cool-tek/Perma Cool:
http://www.cool-tek.com/ (they don't mention the kit as available for my car on thier website, but I have seen prototype pics)
http://www.perma-cool.com
Pic of TRD oil cooler:
Thank You
PS: Can anyone reccomend high quality oil temp, oil psi, and water temp gauges?
[ May 08, 2003, 05:54 AM: Message edited by: rugerman1 ]
